04 XC70
DWNiefer
Post by DWNiefer »
number 11 fuse(engine compartment-20amp) repeatedly went out when starting 2004 Volvo XC70. Relay coil?? Still trying to figure out. Humm?
Thanks, Darryl
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Does the fuse blow by just turning on the ignition or when you actually crank the starter?
DWNiefer
Post by DWNiefer »
Think crank the starter. Sometimes had to replace fuse twice. Sometimes after few cranks. Often first thing in the morning.
Thanks, Darryl
Has thanked: 1611 times
Been thanked: 4071 times
You will need a good wiring diagram to sort out heat that fuse does. Be aware the P2 chassis transitioned during the 2001-2004 years so posts about other model years May or may not apply
DWNiefer
Post by DWNiefer »
After lengthy testing, fuse blown right after turning on ignition or as soon as I turn key on. See head lights briefly on right after turning the key on first click. Not after cranking the engine. Also as soon I put new fuse in it blown. Sigh
FullSizeRender.MOV
(83.78 MiB) Downloaded 65 times
Thanks, Darryl
DWNiefer
Post by DWNiefer »
As soon I turn key on lights flash
IMG_5427.MOV
(6.69 MiB) Downloaded 67 times
Thanks, Darryl
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
turn the lights off.
now turn the key on.
what happens?
DWNiefer
Post by DWNiefer »
Just when turn ignition on it just went on for about one or two secs then off even though lights switch already turned off.
Thanks, Darryl
jonesg
Post by jonesg »
I would check the ignition coil wiring under the engine cover.
DWNiefer
Post by DWNiefer »
Found two wires melted from first ignition coil!
Thanks πŸ™ for suggestions!
Appreciated much! :D
Thanks, Darryl
