1997 v70 auto hit rock
h20ham
Year and Model: 1998 xc
Post by h20ham »
Leaked trans fluid out
Looks like a replaceable cap or housing with 10mm bolts at front left of trans
Will get pictures in am
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
Has thanked: 1502 times
Been thanked: 3817 times
Yes, the cover for the solenoids is replaceable , and still available as a new part for about $75
h20ham
Post by h20ham »
Thank you
It’s a round base that is caved in, on a cylinder. Front drivers side in-front of trans.
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
Has thanked: 1843 times
Been thanked: 1710 times
I believe it #35 is what Abscate is referring to:
https://www.volvooftorontoparts.ca/a/Vo ... 71370.html
Bad news is on this website it is listed as NLA. At least you can get a part number and you may find stock out there still.
Check with Skandix in Germany , too
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Is that not an unmanned corporate radio station?...Auto Hit Rock!
h20ham
Post by h20ham »
Good stuff gents
Still haven’t got it in the air yet to see. Sure seemed like a small cover
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
You may be able to remove it if it is not too bad or holed, and straighten it. Even if there is a small hole, JB Weld or similar can probably fill the hole
h20ham
Post by h20ham »
Cover on drain, where dip stick sits.
Hope she holds
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
I wish you luck!
