The driver's side spring seat has over 100k miles and is still good. The passenger side is about to get its third changeout in the same timeframe. Last repair used the xc90 heavier version. That was 35k miles ago.
Any suggestions on what else I can replace that would make the passenger side spring seat last longer?
Both struts, ball joints and control arms were done same time xc90 spring seat was installed.
04 v70 eats pass side spring seat
- Has thanked: 2196 times
- Been thanked: 1850 times
Did you replace the top plate bearing on your last seat change? If not it may have failed or seized which will load the top spring seat and make it fail early.
- 797 Views
Last post by T64me
- 16 Replies
- 4387 Views
- 3839 Views
Last post by 98v70dad
- 20 Replies
- 3777 Views
Last post by oragex
- 1961 Views
Last post by sleddriver
