Flex Pipe on Exhaust Manifold 1998 V70 Non-turbo question
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
While replacing the exhaust system on my non-turbo 98 V70, I struggled mightily (MIGHTILY) to get those four nuts off. I finally got three off and had to drill out one broken stud. I did everything to these nuts including Liquid Wrench, lots of heat (repeatedly), an impact gun, cold chisels, and bolt extractor impact sockets.
Once I got everything back together and started the car, I found that there is a big leak now in that braided flex pipe that's part of the exhaust manifold. I'm assuming all the banging and moving side to side for access to the nuts broke some sort of seal in there.
1. How does that flex pipe stuff work?
2. I'm thinking of buying the exhaust manifold kit below. I'm afraid a used manifold (if I can find one) may have a defective flex pipe. Anyone have experience with this part from this source?
Professional Parts Sweden
PRO PARTS Exhaust Manifold Kit
Part Number 9471934
Manufacturer PRO PARTS
Manufacturer Part# 21431934
Interchange Part# 1275745, 9135758, 9404751, 9434228
https://www.fcpeuro.com/Volvo-parts/V70 ... 20manifold
(Available for substantially less money elsewhere, by the way, even on clearance at FCP. Also available for substantially more money elsewhere.)
All U.S. market models.
All running and on the road.
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
The flex pipe probably cracked through at one of the webs. The braided outer sleeve makes finding the crack nearly impossible. You could cut off the flex pipe and weld in a replacement as long as the rest of the manifold isn't super rusty and you pay attention to the indexing. Though if the ProParts manifold is available for substantially cheaper elsewhere, than that is likely the cheaper and quicker fix.
My limited experience with ProParts: their non rubber parts seem to be of decent quality for aftermarket made in China.
Eddystone
Post by Eddystone »
Thanks
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
That should be fine. All of them age and wear eventually.
When I had my '96 NA, I welded on a new flex flange (was available as a separate piece) .
Has thanked: 1609 times
Been thanked: 4063 times
Make sure you get a block off for the SAS bung if you don’t have that feature (UFO behind the cylinder head)
Sizes and threads are in this forum
M18 x1.5 is lodged in old RAM
