'02 V70 (Cam Seal explanation)
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 158 times
Been thanked: 6 times
Post by Mr. Detail »
Morning gentlemen;
Well I have been leaking a fair amount of oil over the last several weeks and have kept adding a quart or so every 3-4 days until I could get an appointment with my mechanic. He told me yesterday that my "cam seal" is shot and needs to be replaced. He also said since he is in there he might as well replace the "exhaust seal". Just wanted to better understand from someone what exactly is a cam seal?
Trying to picture that cam's are internal and ask myself why would they need a seal. Looks like I will need to re-replace my recently new timing belt as he said there is probably oil all over the belt.
Has thanked: 1613 times
Been thanked: 4075 times
Cam seals are on the end of the cams and keep the oil in. Check your PVC for pressure as if the pressure popped the seal, it will pop the new one out , too. Adding a seal job onto a side with VVT will add 2-4 of hours labour to the job, or $200-400
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Start at 2:30, Robert points right at them. They are right behind the timing belt gears on the cams.
08 C702.5T (sold)
The non-Swedes:
Mr. Detail
abscate, is that PVC item you spoke of also named "Oil Breather Box". Behind the manifold?
It’s a whole system. Pipes , pTC nipple, hoses , box. All needs to be cleaned
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
abscate wrote: 14 Jul 2023, 08:42 It’s a whole system. Pipes , pTC nipple, hoses , box. All needs to be cleaned
+1
The lubrication system is in need of service after 20 years of good life.
