I did a cylinder replacement once before took me a while.
So used a screw driver to make a groove took forever.
Went to homedepot and pick up a small cold chisel this time. Picture above. Bingo one hit loosened both of them.
Got a coded cylinder put it in no problem.
The new one comes with a plastic tap for the trans cable. Just make sure u use the dummy key and turn it on to remove. Also need to turn the key also to remove cable and insert.
Good Luck Madness
2006 volvo s60 replaced ignition cylinder 30 min
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
volvomadness
also went to hardware store picked up to screws with an allen key to tighten.
- 2659 Views
Last post by 93SCMax
- 18 Replies
- 15063 Views
Last post by LadieRed
- 16 Replies
- 4735 Views
Last post by coded9
- 1210 Views
Last post by precopster
- 967 Views
