Started getting the occasional misfire and CEL with code P0301 the other month. It wasn't happening too often - maybe every 100-200 miles - until recently. I was thinking it was time for new plugs or a coil swap, but then an inspection revealing that the silicone that holds in the bullet terminals in the ignition coil plug for cylinder 1 were completely disintegrated. Without the silicone to hold the terminals in the plugs, I expect they are getting loose leading to intermittent electrical connection.
I realize the long term solution is changing out the wiring harness but that does not appear available for my 98 S90. Any recommendations for repair? Splice in a pigtail?
Cylinder 1 coil plug with no silicone on wire
Bullet terminals loose inside plug
Cylinder 2 coil plug with cracking silicone for comparison
P0301 intermittent misfire and brittle bullets plugs
bill740
- Year and Model: 2006 V70, 1990- 740
There is a connector with a short 6-8 inch wire attached to it. Do a e-bay motor search (ignition coil 960 volvo wire repair) and it will come up
You will have to cut the bad section and splice the new connector on.
fun to drive
- 1531 Views
Last post by WhatAmIDoing
- 1719 Views
Last post by FLXC90
- 433 Views
Last post by rmmagow
- 2030 Views
Last post by Vovo_merz
- 2486 Views
Last post by timothyha22
