I’m about to give up on the car.
Car was running fine previously. Did notice a dip in fuel mileage at the last fill-up, but no apparent issues were present.
Then I was sitting at a stop light, radio on, AC on and the car stalled out. I managed to restart it, basically all the lights on and car was in limp mode. It then stalled at the next stop sign. I got it started once more, but it puttered out and hasn’t started since. The car will crank.
So far I’ve:
-Cleaned and and a friend test the MAF sensor. The voltage changes with air intake, so I assume it’s working.
-Replaced the VR on the alternator
-Replaced the fuel pump relay
-Replaced the battery
-Replaced both Cam and Crankshaft position sensors
The car already had a new ECU and ETC paired and programmed when I bought it, so I don’t think they are the issue.
I haven’t gone the immobilizer route, since the car won’t start at all, and I’m tired of putting new parts on this.
My basic OBDII scanner isn’t getting any codes.
Any hunches? I love my wagon, but I am at my wit’s end.
99 v70 NA will crank but not start
- Has thanked: 2203 times
You don't mention if the fuel filter or fuel pressure has been checked? For your car it should be 50+ psi, mine is nearer 60 psi.
Not sure how you test a MAF. It may be showing readings but are they correct? You need a junkyard one to try, as Volvo is the only other option. Bosch has stopped selling them.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
There is another relay on top the radiator that will cause a no start. Not the 3 plug fan relay. A square grey single plug one on the other side.
Probably not related to your no start but the temp sensor in the thermostat housing will cause fuel economy to drop off it it is failing.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
3p141592654
- Year and Model: 2000 V70
- Has thanked: 3 times
- Been thanked: 3 times
Sounds familiar. You should get a P1670 if you try to start it enough times and it is the immobilizer. First thing I would try is pulling the antenna ring off the ignition and measuring it to see if its 5 ohms across the two inner pins. Also if you have another key try both of them.
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
No start and cranks ... Always start with starter fluid or equivalent first. Spray into vacuum hose off of intake. If it starts for a second or two and stops, fuel issue else check for spark. Report back with findings.
- 17 Replies
- 2714 Views
Last post by Dingo957
- 385 Views
Last post by JimBee
- 1827 Views
Last post by Littlelegs
- 3532 Views
Last post by Empathron
- 1057 Views
