Remove Cross Country from tailgate and trim from doors and fenders?
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
How can the "Cross Country" strip from the tailgate so it will look good on a non-XC? How can the grey trim be removed from XC doors and fenders, replaced with color matching trim from non-XC? I see so many XCs in junkyards but I could use those body panels for a non-XC, so the conversion would help.
FireFox31
Has thanked: 2199 times
Been thanked: 1852 times
Sorry, but I am a little confused. Are you wanting to fit the V70 XC door and tailgate trim to a regular V70? Doors you could swap hole but will need a color matched car for ease. Same would be true for the tailgate. They should all fit the same. Not sure if the trim strips are interchangeable. Been a while, can't recall if the trin is slotted and held by a small screw at the rear edge like an 850 or if they are held on with double sided tape. Sorry.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I have not tried this but a heat gun can be used to soften some adhesives. It might work for removing the trim. Work slowly and use a smooth plastic trim tool to try to pry off after heating. Use GooGone to remove remaining adhesive.
volvolugnut.
FireFox31
Post by FireFox31 »
I'm interested in removing the "Cross Country" banner from below the glass on a tailgate. If it is an adhesive, it will have covered up the old paint, thus sun fade would make that strip darker than any other place. Not ideal.
FireFox31
I seem to recall seeing the banner is just hat, and adhesive application. These days you can get a drill mounted tool to remove those. Downside is as you say, it could be darker under there from not being bleached for all those years.
levalexi
Year and Model: 2000 v70 xc se
Has thanked: 9 times
Been thanked: 6 times
Post by levalexi »
The cross country is a sticker. A rather thick sticker. And the door strips are just held on by adhesive.
There is a rubber(?) disc drill attachment that can be used to remove decals.
This is what I was thinking of, and I think others are suggesting:
https://kiptip.com/products/decal-remov ... by-canopus
I picked this as although Amazon and others sell it, sometimes when I put links to Canadian sources they don't seem to work for others south of the border (like Amazon.ca).
Advice is best to use on a warm day as it helps with the adhesive removal.
I was trying to figure why this car looked wrong. Took a minute to realize the wrong front bumper and front fender side trim!
https://www.kijiji.ca/v-cars-trucks/cal ... 5/m6859538
FireFox31
Post by FireFox31 »
Thanks for the input. Removing the tailgate banner sounds easy. Replacing the fender/door trim sounds harder since I'd have to find an adhesive which will actually stick. I'll save XC70 parts as a last resort.
Weak effort on that T5 to use the wrong front end parts. Makes me wonder if it was in an accident and actually needed all those parts. I want them for Geronimo because, no surprise, what's there is rusted and spray painted.
FireFox31
