2012 S60 brake pedal no pressure Topic is solved
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Need advice on whats wrong with brakes. Brake pedal went to floor and master cylinder reservoir was loosing fluid. I now just replaced the Brake Master Cylinder and replaced the Brake Booster too. Bled the brakes and no improvement on the pedal. The Booster I removed had brake fluid in it so I assume the master cylinder was leaking. Any advice on next items to check or replace. ?
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Has thanked: 987 times
- Been thanked: 1075 times
Did you bleed the master cylinder before installation? It may still have air in the master cylinder.
cuhfs
I may not have bled the Master Cyl correctly. Just took the car out and it seems to have worked itself out, Brakes feel great now.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
if the master cylinder did have air in it, and it worked out, you will want to check the brake fluid level again. It may be low.
- 598 Views
- 1740 Views
Last post by rdtoth
- 2885 Views
Last post by jimmy57
- 2112 Views
Last post by volvolugnut
- 4079 Views
Last post by 204015953
