P80 AWD rear soft brake line replacement 9209896
Has thanked: 1613 times
Been thanked: 4077 times
I had a seep at my left rear brake line, which isn’t good. It turns out the old one ( original) was pinholing at the junction of the hardline and the flare nut at the caliper
FCP had a nice new replacement style with a swage at the caliper instead of the line/flare. You have to tighten at the caliper first, of course, with this design
The AWDhas a bulkhead flare connection on the jack point connector , unlike the FWD cousin with a hard to read Union on top of the rear suspension arm. That’s payback for the rear axle drop needed for other service .
30 seconds of propane heat yielded the Union nut from the piece of the soft pipe, after I cut it off with a Dewalt brake pipe remover
Part from FCP of course
1 minute to bleed air at the caliper, put tire back on, and all set.
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
Just did this on mine too, though not because of a leak. Turns out if you lower an AWD enough the rear brake lines are too short and rub the inside of the wheel. Sketchy! Replaced with front hoses for 280mm brakes and it’s back to rub free
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Has thanked: 2215 times
Been thanked: 1853 times
Yes you have to be careful if you upsize the rim diameter and run P2 offset rims. I had to bend the mount for these slightly on one side to make sure there was a little more room should the tire flex on hard turns!
V50M66
Post by V50M66 »
Yeah, P2 wheels combined with lowered suspension = sketchy. I’m running 17” Neptunes (early P2 XC90 wheel) and lowered, it would rub over bumps and hard turns with the factory lines. A little more length fixes that issue
