control arms
mrbrightside2009
- Year and Model: 96 850 turbo
- Has thanked: 1 time
96 850 turbo...mine seems to have the 4 bolt configuration for the control arms...i am only seeing that setup for s70's online... and i am only seeing 2 bolt configuration for the 850's...do i just buy the ones listed for the s70?
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
The 850ies had 2 bolts towards the frame and a removable ball joint for the early years. The Diesel 850ies had a different mounting pattern towards the frame, could bel 4 bolts.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 2202 times
We didn't get diesels this side of the Atlantic unless possibly private imports. So if you have owned the car from new then it is an anomaly if it has a 4 bolt control arm. Can you post a picture for us?
If you have not owned the car from new, it may have had an accident and someone fitted a later front subframe from a V/S/C 70 P80.
If that is the case then a regular 4 bolt part should be fine.
- Been thanked: 4068 times
I think you have a swapped subframe. You need to match bolt pattern of course.
mrbrightside2009
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Yup. 4-bolt. Are the bushings for the subframe aluminum? Someone has probably swapped in a C70 convertible SF.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
4 bolt.mrbrightside2009 wrote: 25 Jan 2024, 05:54 Back on this again...so I am going to post a pic of this arm...definitely looks like the 4 bolt configuration if someone can confirm this. I snapped a quick pic last night did not really look under there too well.
8628497 and 8628498
The usual warning about avoiding URO anything.
- foggydogg
Agree with the others, subframe swapped. C70 or an AWD platform. Raising the motor up a bit helps with access to the bolts; pack your patience, it isn't a ten minute job.
I quoted an hour for a 4 bolt control arm once, based on the two bolt design, and the Creator humbled me.foggydogg wrote: 25 Jan 2024, 07:12 Agree with the others, subframe swapped. C70 or an AWD platform. Raising the motor up a bit helps with access to the bolts; pack your patience, it isn't a ten minute job.
