My daughter came home to visit from Boston last weekend and reported a scraping sound from the car. Luckily she was close to getting off the highway and was only 15 mins from home. Her boyfriend identified a dragging heat shield as the problem.
We lifted the car up and examined the situation. I didn't have much time to work on the car and had to come up with a quick solution that didn't involve ordering parts.
The heatshield sits between the exhaust pipe and the tank with not a lot of space between them. It is held in place with 3 rubber mounted M6 studs. Two of them were rusted off, and the remaining one acted as a nice pivot point, so that the back end of the heat shield was able to nicely dangle on the ground.
Instead of messing with those studs I decided to attach the heat shiel to the pipe instead, and it worked out fine.
I had two 2 1/8" exhaust clamps that fit nicely around the exhaust pipe. After loosely mounting them I marked the hole pattern of the clamps on the heat shield while holding it roughly in the same position. Then I drilled generous thru holes in the heat shield.
Since there is not a whole lot of room for hands I installed the whole assembly loosely kind of tilted down. When all the nuts were in place I turned the heat shield upward and tightend everything down. Enough rambling, photos will say much more:
850 Gas Tank Heat Shield Fix
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
Nice work. Back on the road in no time!
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
- 2178 Views
Last post by s2zeller
- 546 Views
Last post by Flyingdutchman
- 1724 Views
Last post by cn90
- 623 Views
Last post by kahl
- 3284 Views
Last post by rick4484
