XC70 - Front headlights swap
Stonedraider88
Year and Model: 2005 XC70
Post by Stonedraider88 »
Hi everybody!
My front lens on the right is showing age and has gone all blurry. I can try to polish it and hope for the best, however, I was wondering if the v70 (2001) lenses would fit (they are glass)
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Stonedraider88 wrote: 15 Aug 2023, 04:10 Hi everybody!
The 2001 may not fit. You can search the part number and map it for fitment; try this https://www.ipdusa.com/Catalog/Index?se ... 0headlight
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
The glass headlights pre '05 will not fit. I've had good results making plastic headlights look new by wet sanding with 800-1000-1500-2000 grit sandpaper in that order followed by power polishing with a cut and polish like Meguiars or 3M.
2003 XC 70 (sold)
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Wiring plug is different on pre-facelift
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Stonedraider88
Blacklab467 wrote: 15 Aug 2023, 07:45 The glass headlights pre '05 will not fit. I've had good results making plastic headlights look new by wet sanding with 800-1000-1500-2000 grit sandpaper in that order followed by power polishing with a cut and polish like Meguiars or 3M.
Noted, thanks! I will try to polish them as you suggest, do I need to put any kind of film or clear coat over the lens after? I am wondering how long will the polish last.
Stonedraider88
P80GLT wrote: 15 Aug 2023, 09:28 Wiring plug is different on pre-facelift
Got you, thanks!
Stonedraider88
xHeart wrote: 15 Aug 2023, 07:36
Got you, thanks!
I also have a faulty body position sensor, so the headlights droop to the lowest position. So at the moment the motors in the headlight assembly are unplugged and are manually set up so they dont move. However this throws up the "headlight failure" message. I know where the sensor is located and it seems like an easy replacement, however I read up somewhere here that it needs programming, any pointers on that? Also I am struggling to find the actual part number, there are two types and I am not sure which one is for the XC70 P2.
Is this it? Part number - 31300198
vtl
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Stonedraider88 wrote: 15 Aug 2023, 11:37 Noted, thanks! I will try to polish them as you suggest, do I need to put any kind of film or clear coat over the lens after? I am wondering how long will the polish last.
UV-resistant coat is pretty much must or it won't survive even a few weeks. Some kits come with such coat, like Sylvania headliht restoration kit.
Still, it's a temporary measure. I had to do it roughly once a year. Wrapped in polyurethane film a few years back, it's not perfect and still yellows, but at least it ages better than just polished lens.
