1998 v70 GLT hesitation accelarating
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
ok so I have the low pressure turbo
my acceleration is a little ....hmmmm...not smooth
no heck engine lites
I'm thinking fuel filter
does this model have the fuel pump in the tank with the filter sock?
and are there any other filters in the fuel system?
I have new plug wires that will be installed soon as part of my stage zero efforts
maybe I just need a RIP kit....hahhaha ( serious, do those makes a difference? can you feel the speed or is the throttle more instant reponses?)
thanks in advance!
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
Has thanked: 2211 times
Been thanked: 1852 times
Save money on the RIP kit for doing the stage 0. I'm sure those that claim RIP kits are the best thing ever are the resellers of them. On a standard car I believe it improvement is negligible if any. Just like the cone filter intakes. Most are a waste of money.
Yes there is a fuel filter. On your car it is a can just forward of the RHR wheel under the car.
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
Highly suggest a stage 0 refresh - new plugs, wires, cap, rotor, and coil (use only Bosch - ask me how I know). It’s also not a bad idea to also replace the camshaft and crankshaft position sensor, as faulty ones can and do cause phantom misfires and/or misfire codes
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
surfbug1
Post by surfbug1 »
V50M66 wrote: 22 Aug 2023, 21:00 Highly suggest a stage 0 refresh - new plugs, wires, cap, rotor, and coil (use only Bosch - ask me how I know). It’s also not a bad idea to also replace the camshaft and crankshaft position sensor, as faulty ones can and do cause phantom misfires and/or misfire codes
ok
so I will be on the hunt for a new coil. new crankshaft position sensor. a new camshaft position sensor.
these all seem to be plug and play and easily replaceable.
any major issues in replacement? or just dive Right In LOL
Al
Ping me!
:D
surfbug1
Post by surfbug1 »
Also,
prolly not a bad idea to replace all the hoses and vac / pressure hoses with upgraded silicon
anyone ever done this? seem like a big job with all the routing and stuff, and the engine still in the car
any advice or hints / diagrams?
other then plan on lots of cussing and complaining along the way!
Al
Ping me!
:D
V50M66
Post by V50M66 »
surfbug1 wrote: 25 Aug 2023, 11:17
ok
Al
Nope, no real issues. You’ve gotta take the intake box out for the crank sensor, which is pretty easy, and the over the engine pipe has to come off for the cam sensor. Air box has to come out for coil. Also do plugs and wires.
Also, only go Genuine or OE on the coil and two sensors. The cheapo ones will fail without warning and if the go, will prevent the engine from starting/running.
surfbug1
Post by surfbug1 »
actually running lots better!
new wires
new msd high perf coil
new cold air intake from IPD "short intake"
I have to get new plugs in there and do a compression check, then install my Rip Kit .....
that should wake her up even more! but yeah the hesitation is pretty much gone
maybe I have my foot in it so much, just to hear the turbo whine, that I'm not paying attention to hesitation! lol
will have a good idea after plugs comp test and rip kit
thanks!
Ping me!
:D
Plugs will likely be a big difference. Make sure they are gapped to 0.028". Glad to hear there is an improvement!
surfbug1
Post by surfbug1 »
scot850 wrote: 05 Nov 2023, 19:12 Plugs will likely be a big difference. Make sure they are gapped to 0.028". Glad to hear there is an improvement!
didn't know the plugs were that much of a difference
it's so much better now I'm enjoying it as is! glad the hesitation is gone
will work on that plugs next weekend
al
Ping me!
:D
