1999 S70 GLT.
When I turn the key to I, II, III there is a loud humming noise (sounds like a radio controlled small model plane) coming from right side of the engine bay (right as the driver sees it). I cant pinpoint it, however its somewhere below the alternator as best as i can tell. what might that be? and is that normal?
Question on a noise coming from engine bay
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Any chance you can record the noise or post a video? This would be extremely helpful.
- Has thanked: 2199 times
- Been thanked: 1851 times
+1 on recording it. I can't think of anything electrical down there other than the alternator and AC compressor. An older turbo with a engine oil cooler thermostat can make a noise but the engine has to be running. When you say Pos I, II, III? III is when you start the car so the noise stays there when starting??
Otherwise I am stumped unless it is noise transfer from the ETM trying to self test?
- Grantkat
Here is a video
IMG_7371.mov- (12.51 MiB) Downloaded 57 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Grantkat
that video is with the key turned on but not started
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
You will need a stethoscope to try to isolate where that is coming from. I have no idea what could cause that issue. Does the car start and run ok?
- Grantkat
Car starts and runs perfectly. I will grab my stethoscope and try to figure out where that’s coming from
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Grantkat
Ok here is more information. I have not quite figured out specifically what is causing the noise. However the noise is loudest when I place the stethoscope on the head light housing. I Place the scope everywhere i could reach, but the housing was the clear winner. I unplugged each light and all the lights at once including the turn signal and it did not make a difference. Im thinking i might remove the light house and see whats is what..
any ideas?
any ideas?
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Grantkat
That was it!!! Thank you! Unplugged it, no noise, plugged back in and there it was!
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- 13 Replies
- 3138 Views
Last post by Driven
- 54 Replies
- 13994 Views
Last post by Caineyanko
- 293 Views
- 962 Views
- 481 Views
