Oil pan removal, do the bolt threads need to be sealed?
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
As a step 2 in PCV overhaul that I did a couple months ago, I'll be dropping the pan this weekend to clean and reseal and replace the cooler line hoses. I've seen where others have sealed the bolt threads but cannot find anywhere that this is necessary. Can anyone provide some guidance on this, thanks.
2003 XC 70 (sold)
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
Up around the front crank seal, you will see oil coming out of removed oil pan bolt threaded holes. Not sure if there was one, two or three, but I cleaned up the bolts really good and put Teflon pipe dope on the threads.
Be prepared to clean out the PCV block drain channel.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
- Blacklab467
Thanks, thats the main purpose and goal of removing the oil pan, I was suspicious of that return channel and wanted to get it clean, also to replace the cooler hoses.
2003 XC 70 (sold)
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Blacklab467 wrote: 01 Sep 2023, 07:35 Thanks, thats the main purpose and goal of removing the oil pan, I was suspicious of that return channel and wanted to get it clean, also to replace the cooler hoses.
...more here viewtopic.php?p=491703
- Blacklab467
Thanks, does anyone have the torque and tightening sequence for the oil pan bolts? I found something on Swedespeed but I don't really trust those guys.
2003 XC 70 (sold)
- Been thanked: 4068 times
Blacklab467 wrote: 01 Sep 2023, 13:58 Thanks, does anyone have the torque and tightening sequence for the oil pan bolts? I found something on Swedespeed but I don't really trust those guys.
Snap, ping
- 1138 Views
Last post by DanSC
- 3162 Views
Last post by pmondrian
- 970 Views
Last post by polskamafia mjl
- 20 Replies
- 4458 Views
- 1272 Views
