Got all the parts to do a manual swap on my 850 - plus stage zero maintenance and other upgrades. Decided to go a different direction and now selling everything.
All parts are brand new still in packaging unless notated (used). Additional pictures available on request. Zelle/Venmo/CashApp/Paypal F&F accepted.
Located in Tempe, AZ - will ship at actual cost or local meetup. Feel free to make an offer. All items will be going up on eBay, FB Marketplace, and OfferUp!
* For anyone interested in shipping the transmission - the cost is actually not too bad ~$sold via UPS Ground - I'll do $sold shipped! *
* UPDATED 9/9 *
ADDED:
Depo Headlights (set) - v70 - $ 325
Depo Clear Corners (set) - v70 - $ 80
Instrument Gauge Cluster (used) - $ 150
Forge Motorsport BOV Kit - $ 250
Strut Tower Brace - $ 150
MANUAL SWAP
Clutch Hydraulic Hose - Volvo - 9181324 - $ sold
Clutch Master Cylinder - ATE - 9163880 - $ sold
Clutch Pedal Assembly - Volvo - (used) - $ 150
Clutch Pedal Return Spring Kit - Volvo - 271805 - $ sold
Clutch Pressure Plate Bolts (x6) - Volvo - 959219 - $ 20
Clutch Release Bearing - Sachs - 9181780 - $ 60
Console Trim - Volvo - (used) - $ 40
Flywheel (SMF) incl Resurface - Volvo - 9454774 - $ sold
Flywheel Bolts (x12) - Volvo - 9454743 - $ sold
M56 Axle Seals - Corteco - 6843481 - $ sold
M56H Transmission - (used) - $ sold
Manual Shifter Assembly - Volvo - (used) - $ 125
Pressure Plate & R Clutch - Volvo - 272218 - $ sold
Shifter Cables - Volvo - (used) - $ sold
Slave Cylinder - FTE - 9181017 - $ 65
Slave Cylinder (internal) - 31259445 - $ 90
Throttle Cable (manual) - Volvo - 9157600 - $ sold
STAGE ZERO
Distributor Cap - Bosch - 3501944 - $75
Distributor Rotor - Bosch - 1367783 - $ 35
PCV Kit - IPD - 124711 - $ 115
PCV Oil Trap - Volvo - 9146756 - $ 35
Radiator Hose (lower) - Rein 9470409 - $ 20
Radiator Hose (upper) - Rein - 1335433 - $ 12
Spark Plug Set - Volvo - 8692071 - $ 45
Spark Plug Wire Set - Bougicord - 9135700 - $ 50
Thermostat (90 deg) - Volvo - 271664 - $ 20
Water Pump w/Bolts, Gasket - Aisin - 30751700 - $ sold
ENGINE
960 MAF Housing - $ 35
Auxiliary Cooling Fan - MTC - 9141249 - $ 120
Boost Pressure Sensor - Pierburg - 722908030 - $sold
Crankshaft Seal (Rear Main) - Volvo - 9458178 - $sold
ECU Air Duct Cooling Hose - Volvo - 8619305 - $ 20
Electric Fuel Pump Relay Kit - Aftermarket - $ 20
Engine Mount (front left) - Corteco - 6801722 - $ 30
Engine Mount (front right) - Rein - 8631698 - $ 36
Engine Mount (rear) - Corteco - 9434435 - $ 32
Engine Torque Rod - Hutchinson - 9141042 - $ 30
Engine Torque Rod Bushing - Volvo - 9434263 - $sold
Exhaust Downpipe 3" (angle) - OBX - (used) - $ 250
Firewall Bushing Kit (Poly) - IPD - 8631159 - $ 25
Fuel Injectors 650cc (x5) - $ 175
Heater Core - Nissens - 9144221 - $ 75
Heater Core Coolant Pipe - Volvo - 9134978 - $ 90
Intake Manifold NA - Volvo - (used) - $ 100
Intercooler Aluminum - Aftermarket - 9492730 - $ sold
Japanifold - Volvo (used) - $ sold
Serpentine Belt - Gates - K060685 - $ sold
Silicone Hose 5mm (20 ft) - 121613 - $ sold
TD04-18T Turbo - Volvo (used) - $ sold
Timing Belt - Gates Racing Blue - T252RB - $ sold
Timing Belt Idler Pulley - INA - 8630590 - $ sold
Timing Belt Tensioner - Febi Bilstein - 9146693 - $ sold
Timing Belt Tensioner Pulley - INA - 9135036 - $ sold
Turbo Cooling Hose Set - do88 - KIT24S - $ 25
Upper Engine Bushing (Poly) - IPD - 8631159 - $ 24
SUSPENSION
Bump Stop - Febi Bilstein - 3516327 - $ 20
Control Arm - Meyle HD (left) - 8628495 - $ 40
Control Arm - Meyle HD (right) - 8628496 - $ 40
CV Axle Shaft Kit (both) - 3989020KIT - $ 125
Lowering Sport-Spring Set - H&R - 29958 - $ 200
Shock Absorber - Koni STR.T - 8050-1080 - $ sold
Shock Mounts (x2) - Hutchinson - 9461524 - $ 30
Strut Mount Bearings (x2) - Sachs - 31200599 - $ 100
Strut Mount Spring Seats (x2) - Sachs - 30683637 - $ 40
Subframe Bushings (x4) - Delrin - $ 180
Suspension Struts- Koni STR.T - 8750-1060 - $ sold
Suspension Strut Dust Sleeves (x2) - Volvo - 9140068 - $ 20
Sway Bar Links (x2) - Meyle HD - 31212730 - $ 20
Tie Rod End - Meyle (left) - 271598 - $ 10
Tie Rod End - Meyle (right) - 271599 - $ 10
BRAKES
Brake Hose (front) - Techna-Fit - 9191400 - $ sold
Brake Hose (rear) - Techna-Fit - 9492354 - $ sold
Brake Hose (rear) - Techna-Fit - 3516568 - $ sold
302mm Brake Caliper Brackets - Skandix - 8251319 - $ sold
Brake Rotor (rear) - Zimmermann - 31262099 - $ sold
Brake Rotors 302mm - Zimmermann - 31262095 - $ sold
Parking Brake Hardware Kit - TRW - 51990722 - $ 10
Parking Brake Shoe Set - Textar - 31262626 - $ 25
Yellowstuff Brake Pads (front) - EBC - DP41362R - $ 100
Yellowstuff Brake Pads (rear) - EBC - DP4104R - $ 60
LIGHTING
Headlamp E-Code Lens (left) - IPD - 6817004 - $ sold
Headlamp E-Code Lens (right) - IPD - 6817005 - $ sold
*UPDATED 9/9* 850 Manual Swap Parts + Depos + Will Ship M56H
Gr1mReaper
- Year and Model: 1998 V70 T5
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Sent you a message over on SS.
- Been thanked: 4069 times
Just wanted to note that THIS is how you list stuff for sale
Well done!
Well done!
davidhayes
- Year and Model: 1995 850 T-5R
PMd. I'm interested in the 850 manual shifter assembly.
'95 850 T-5R yellow sedan @ 278k
washirley1
What of the manual swap is available, now?
5underpressure
- Year and Model: 1998 v70
- Has thanked: 11 times
- Been thanked: 13 times
I would like to purchase some of your stage zero stuffs.
