Can I jack up the car from the lower control arm?
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I don't have ramps, but I have some wooden blocks I screwed together that are 6 inches tall that I want to put under the wheels to lift the front of the car. I was able to use these for another car that had an axle that I could jack from. Since I can't jack the car up high enough to get the wheels on it, can I put a jack under the lower control arm, to raise the tire? Or would this break something?
2002 v70 X/C 288k miles
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
No, you will bend it. Put some 2x4 under your floor jack.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
youtube has lots of examples of diy wood ramps, or look for used ramps online.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Do the lift in multiple steps until you get to the full lift height.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Agree with these guys.
I only lift from the front crossmember or subframe, or the jack points under the doors. You can do one side at a time if that works for you.
