headlight conundrum 99 S70
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
1999 S70 GLT. I have a weird issue with the passenger side headlight. This one has me scratching my head. The left light has a focal point, the right one does not. No matter how i move or adjust the aiming nothing changes. I can put my hand on the lens the you see the light dull somewhat. there is no dimming of light on the left or right so I know it is not aimed way off. its like somehow what would normally be a beam directed forward is being diffused. Also i popped the clip holding the internal bracket in place and was able to pivot the inside bracket with the light on..made no noticeable difference..
I have a spare set of a donor car (not sure of year or model, but i place to check it out and see if i can figure out what is going on
I am including some pictures.
any ideas??
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
Grantkat
Post by Grantkat »
I will add that the two lights look exactly the same looking into the assembly from the back.
1999 S70 GLT ~193k
2014D VIDA/DICE
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Grantkat wrote: 07 Sep 2023, 19:39 I will add that the two lights look exactly the same looking into the assembly from the back.
Most likely the reflective coating gave up. Swap it out would be my suggestion.
Several thousand keystrokes on here about our lights. Carefully curated used units or TYC seem to be the only reasonable fixes.
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
100% burned reflectors. Swap the one headlight for a good one and you’ll be back to normal. Mine did that too, same side (though I took the expensive route and went Jewels with projectors for far superior light output)
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Has thanked: 1611 times
Been thanked: 4072 times
Reflectors are dulled but if you look closely you will find left amd right Volvo glass have different lenses , too
Grantkat
Post by Grantkat »
thanks everyone...will do!
1999 S70 GLT ~193k
2014D VIDA/DICE
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
How to refurbish if the spares don't work out. Middle of the page.
viewtopic.php?t=100706&hilit=Project+2000&start=20
