I'm stumped and can use some input. Unless I use the shifter override the shifter is locked in P. Dash says D.
I thought it was the gear shift mechanism so I replaced the entire unit with a good used one. Did not fix it.
Also can wont shut off since its in Drive.
The brake pedal light / sensor is working properly as the brake lights work.
I can use any advice or ideas you have. Thanks!
2012 S60 Shifter locked in P, Dash shows a Drive Topic is solved
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
More i research more it looks like TCM
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Grateful to dealer. Had car towed to Volvo dealer in Nazareth Pennsylvania. They found under the hood shift cable no longer held in place (out of bracket). Did not fit in bracket tightly anymore and they replaced $17 bracket + diagnostic time / labor. No TCM issue; no gear shifter issue. just a plastic bracket and a couple hundred bucks. - its a win! Also note sometimes "shade tree mechanics" like me just don't know where to look. Hope this helps others.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 1819 Views
Last post by Sommerfeldt
- 1887 Views
Last post by jenkinskg
- 13 Replies
- 2546 Views
Last post by smoggyama
- 7934 Views
Last post by oragex
- 1101 Views
Last post by June
