2008 C30 Fuse panel replacement
Pretribrapper
Year and Model: 2011 C30 2.0 T5
Has thanked: 59 times
Been thanked: 9 times
Post by Pretribrapper »
Looking to replace my fuse panel under passenger side dash. There was quit a bit of corrosion in it and my power drivers seat is not working. My scanner showing me that there is an issue in the CEM and I believe the unit needs to be replaced. My question is if I find a used unit with the same part number can I simply swap with mine or is there additional programming needed? 31254903 is the part number on mine and I am looking at one from an s40 that had the same box. Will it work?
