1999 s70 NA fuel trim problem Evita P0172 [ Fixed with oil change] Topic is solved
Has thanked: 1610 times
Been thanked: 4065 times
Evita is coding very 500 miles or so with a P0172, system too Rich.
Fuel pressure checks in at rail at 43 psi, on spec.
STFT is short term fuel trim
LTFT is long term fuel trim
Here is the weird behaviour.
At idle , STFT SITS AT 8% , a bit high for an engine with 175k but , whatever. LTFT settles at -7% so overall trim 1%, quite good
Under load or rpm, the STFT rails at 20% and he long term trim then rails at -20%. Same net fuel trim but trying to figure out why this happens.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
How old are the oxygen sensors? I would start there.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Front brand new , maybe 12 months 7500miles
On edit - 3 years old, 12,000 miles
But, that’s a good check, added to list
Fuel pressure again
Intake manifold leaks
Exhaustleaks
Leaking fuel injectors
Plugged cat
OXS
Swing test here
One of these should get it
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
43.5psi is correct fuel pressure for up to '99.
ME7 should have more...around 60psi?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
misha wrote: 23 Sep 2023, 17:24 43.5psi is correct fuel pressure for up to '99.
'99 NA in the US market uses Denso engine management. I believe 43 PSI is the spec for the Denso cars, and 51ish for ME7.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
We had this same code but on a 98, it turns out the O2 sensor wires were unplugged just enough that it didn't throw codes, but must have been throwing the voltage readings off. Pressing on the connectors clipped them into place, and voltage values read through Torque seemed to go back to normal. Probably something you already checked but sometimes it's the simple things.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
Now I’ve got lots of spare parts to try…
Pulled fuel rail and cranked. Nice even pattern, no drips. I could also rule out leaking injector from good fuel pressure holding, too.
Interesting. I never got back to diagnosing this , but when I hit the 180,000 oil change mark, it stopped coding.
I checked fuel trims and both LT and SAt are under 1%
Fuel in oil perhaps?
Has thanked: 2199 times
Been thanked: 1852 times
Maybe bad fuel or possibly a leaking injector that fixed itself. Seems strange that an oil change would fix it otherwise?
Neil
