I am going to be undertaking a front strut replacement in the not too distant future. I can spin the nut on the top of the strut. as far as capability, I am able to use a spring compressor and change individual components or use a quick strut, I am on the fence about which way to go. Here are my questions.
Am I better off picking components and reusing the original spring? or is there a solid quick strut that would do that job
I welcome comments and thoughts.
1999 S70 GLT - looking for input/advice
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Has thanked: 1611 times
- Been thanked: 4072 times
What are your long term plans for the car?
The quick strut kits save a lot of labour but are 30-50k life products at best. Worse, if your roads are crappy
- Grantkat
long term. I plan to drive this for the foreseeable future, short of a catastrophic failure. I live in southwestern Ohio - by definition our roads are 3 levels below crappy. I live in a continuous cycle of bad roads, long construction cycles resulting in bad roads....Im all in. so...
your thoughts on component replacement??
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
Get thee to FCP for
Sachs struts
Volvo our Lesjefors Springs
Volvo oe strut bearing from the xc90
For another 120-150k life of stuff.
Sachs struts
- Grantkat
awesome !!
thanks for thee for the info
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Whenever I do suspension work I always start with the rear suspension. You'll be surprised how much better the car handles besides getting a better feel what is really happening up front.
On our 2000 S70 purchased last year, I've installed the rear Blaupart shocks along with FCP purchased springs. The height is back to normal and car feels very planted. Hopefully the fronts will be installed before winter. A member from another forum confirmed Blaupart has been very good on his S70 after someone asked what I thought of them.
The springs was also a recommendation from an owner with several S & V70. He had tried the OE and others but found the 850, V70 unit worked the best and didn't sag with time. The ride and handling has been excellent after several months of use.
In 2012 I'd purchased a 98 S70 T5 with 230K miles and used the Gabriel Quick Struts up front and their Ultra Shocks for the rear. If you want a soft and supple ride the Gabriel's are a good choice also. Only had the car for 2 or so years and it was solid the entire time.
Good people and easy to work with.
Front Rear Volvo S70 Shock Strut Set - 1998-00 - 2WD
Special Price $63.98 Regular Price $127.95
https://www.blauparts.com/front-and-rea ... s-set.html
Volvo Coil Spring - Lesjofors 9140099HD
https://www.fcpeuro.com/products/volvo- ... hd#fitment
Gabriel Ready Mounts Struts Front G57040
(www.amazon.com/Gabriel-G57040-ReadyMoun ... 106&sr=8-1)
Gabriel Ultra Shocks Rear 69901
(www.amazon.com/Gabriel-69901-Passenger- ... merReviews)
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Why for an XC90?abscate wrote: 05 Oct 2023, 09:10 Get thee to FCP for
Sachs struts
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2209 times
I think Abscate may be off on the strut bearing. I may be off base, but I think he may mean the upper spring seat. Volvo changed all P80 spring seats to the XC90 version due to early failures of the original. The XC90 is a kind of HD unit.
There is a strut bearing as well. Volvo supplies this as well, but the Sachs (OEM) is ok as well.
- 1326 Views
Last post by davidcschulte
- 466 Views
Last post by matthew1
- 12 Replies
- 5410 Views
Last post by j-dawg
- 2284 Views
Last post by kanona40
- 1081 Views
Last post by 800artfreed
