Coolant bottle hoses 1999 S70
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 128 times
Post by 454cid »
I have a coolant leak, and I believe it's the bottle or lower hose. Before I start ordering parts, I'm wondering if that lower hose could be replaced by bulk hose. Is the diameter the same on both ends? Is it 3/4"/19mm or something in between common sizes? I think 1" is also available in bulk.
Would epoxy fix a crack in the factory Volvo bottle?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1834 times
Been thanked: 1709 times
The system is only pressured up to the max 15 psi which is the cap valve limit. So typically the pressure is lower in the coolant system.
Gluing may work, but as it is warm water and chemicals in there I'm not sure how well that will work. Maybe use a soldering iron and melt the plastic on the outside of the crack in the bottle, then scuff the surface, clean with rubbing alcohol and then try gluing it over the top. I think the pipe takes a sharp 90 degree out the bottom of the bottle. Maybe you can replicate with one of those internal springs to prevent hoses collapsing on bends?
454cid
Post by 454cid »
scot850 wrote: 13 Oct 2023, 15:41 The system is only pressured up to the max 15 psi which is the cap valve limit. So typically the pressure is lower in the coolant system.
I've been thinking about how to handle this for a couple of days now. I took a look at the pictures online of the correct hose, since you mentioned the bend. It's not quite 90, by the pictures, and MAYBE a piece of bulk hose would be okay there, but I noticed it looks like each end is a different diameter. I'll just buy a molded hose, I guess. Probably get a new bottle, too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
It sucks, but then I don't think the designers ever thought many of these cars would still be around 25-30 years later!
