I want to trickle charge our son's 06 XC70. I know you can jump start the car from under the hood, but can you also trickle charge the battery from there as well to save having to pull the crap out the load bay.
If you can, I assume you connect the +ve to the marked connection in the engine bay, and do you use any ground for the -ve as I do in my P80?
Thanks,
Re: Trickle charging a P2 XC70 - Question?? Topic is solved
- Has thanked: 2197 times
- Been thanked: 1851 times
Well I have used the instructions for jump starting the car and connected the +ve to the connector under the hood and the -ve to the alternator bracket, again as per the handbook. Powered up the trickle charger and nothing went bang so I guess that is a bonus! Trickle charger seems happy so I guess I may find out tomorrow how it has done. Car may not need it but it has been sitting for about 6 weeks or so unlocked in the garage. Hopefully all should be good. Worst case it just doesn't charge the battery.
It appears to have charged the battery and gone into maintenance mode now. So seems to have worked. I will have to get it moved on Thursday so we will find out if everything is good!
Thanks for the help!
Update. All is good!
- 1889 Views
Last post by RickHaleParker
- 666 Views
Last post by jonesg
- 42 Replies
- 6473 Views
Last post by crlande
- 1068 Views
Last post by teyloradam
- 1135 Views
Last post by DeeSi
