Did you know? 🤔
S90 Turn Signal flasher relay location?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Nobrun
Year and Model: S90, 1998
Has thanked: 0
Been thanked: 0
Nobrun
Re: S90 Turn Signal flasher relay location?
Post by Nobrun » Mon Apr 08, 2013 3:13 pm
lindy8_man wrote:Mystery Solved!
...two electrodes on the bottom that have solder contacts. The solder melted together, and all those 12 volts go in the direction of least resistance...
Thank you very much for posting this online. I however just scraped off the melted parts (I figured new bulbs will end up melting again-same problem). My turn indicators/hazards are now working perfectly.
billofdurham
Year and Model: 855, 1995
Has thanked: 0
Been thanked: 3 times
billofdurham
Post by billofdurham » Tue Apr 09, 2013 12:14 pm
It is good to know that someone knows how to search for answers. Glad it helped.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Firebreather92
Year and Model: 1998 s90
Has thanked: 0
Been thanked: 0
United States of America
Firebreather92
Post by Firebreather92 » Mon Jan 28, 2019 4:07 am
Hey guys I'm starting to get a little agitated because I've looked by the hazard switch I've looked in the fuse boxes I cannot find the turn signal relay if anyone can help me find it I have a 1998 Volvo S90. If you're able to point me in the right direction I would greatly appreciate it. I did notice once I disconnected the hazard switch then plugged it back in it worked so could it be the hazard switch causing the problems and not a turn signal relay.
lummert
Year and Model: 760 1988
Has thanked: 0
Been thanked: 14 times
lummert
Post by lummert » Wed Jan 30, 2019 7:56 pm
The Hazard Switch/ turn signal relay are combined into this 5 inch long Hazard switch assembly on my 1988 Volvo 760 Turbo Wagon. My turn signal had failed, but the hazard lights still worked. Replacing the Hazard Switch cured the issue.
dm635
Year and Model:
Has thanked: 0
Been thanked: 7 times
dm635
Post by dm635 » Thu Jan 31, 2019 8:55 am
I have an '87 6 series BMW. I know for a fact that the turn signals do go through the hazard switch. If there is a problem with the signals it very well could be related to the hazard switch. I found this out by accident while doing some work and went for a drive with the hazard switch disconnected.
96-964
91'745
86-635CSi 215K
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945
ramseykira91
Year and Model: 1998 Volvo s90
Has thanked: 0
Been thanked: 0
ramseykira91
Post by ramseykira91 » Mon Dec 02, 2019 9:02 pm
I was also having the same problem with my 98 s90 and thanks that is forum I fixed mine for 10$ thank you so much. The mechanic was going to charge me $120 an hour. You guys saved me at least $110. Thank you so much happy holidays and God bless!
lummert
Has thanked: 0
lummert
Post by lummert » Tue Dec 03, 2019 10:55 am
You're welcome. With my 1988 760, the turn signals didn't work but the hazard flasher did. This is what caused my confusion. I now carry a spare hazard switch.
