Identifying turbo vs NA axles Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So I was in the junkyard today grabbing some interior bits, and I noticed that the '95 GLT I was harvesting from had a turbo gauge on the dash. I thought the GLT in '95 was just a trim package, not a low pressure turbo, but there was the dash gauge. I looked at the axles, and the boots were perfect, so I set about taking out the axles to keep as spares. As I got started, I noticed that it was a NA engine after all. Weird.
I looked at the passenger side axle, and it seemed to be a smaller diameter shaft running to the trans than the one on Sveedy ( turbo ).
Is that actually true, or are my eyes deceiving me. Is there a way to tell the difference without removing the axles ?
1999 V70 GLT
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Sveedy wrote: 22 Oct 2023, 16:04 So I was in the junkyard today grabbing some interior bits, and I noticed that the '95 GLT I was harvesting from had a turbo gauge on the dash. I thought the GLT in '95 was just a trim package, not a low pressure turbo, but there was the dash gauge. I looked at the axles, and the boots were perfect, so I set about taking out the axles to keep as spares. As I got started, I noticed that it was a NA engine after all. Weird.
I would go to FCP, IPD, RockAuto and Volvo Parts Online and check fitment between the 2 models in question. It's better than visual as it could be from another Volvo OEM supplier so looks can be deceiving.
Sveedy
Post by Sveedy »
Well I'll be dipped ! Apparently they use the same axles. I could have sworn that I had read that there was a difference between the turbo and NA.
Guess I'll go back and get them. I might measure the shaft dia. anyway.
1999 V70 GLT
MoVolvos
Post by MoVolvos »
Sveedy wrote: 22 Oct 2023, 18:41 Well I'll be dipped ! Apparently they use the same axles. I could have sworn that I had read that there was a difference between the turbo and NA.
Glad you'll have some good spare parts. I just replaced two axles on the 08 C30 T5 and the newer aftermarket units are thinner than factory. Only tested them on the freeway for about half an hour and they seem fine. One is from O'Reilly the other Amazon.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
NA and turbo P2 cars have different axles .
Outer CV is beefier on the turbo axles. This means the boots are different diameter too. However fitment (shaft diameter, splines) is the same. Take a look to compare if/when you get them home. Theoretically you don't want to run NA axles in a turbo long term, but can go the other way no problem. Don't think I've ever heard of an NA axle failing when run on a turbo though, to be fair.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
I just tossed an original NA pass axle over the weekend. The inner axle (between the carrier bearing and the transmission) is a smaller diameter than the turbo ones.
Sveedy
Post by Sveedy »
^ That is what I thought I was seeing. I'll measure both and go from there.
Thanks for clearing this up.
1999 V70 GLT
Chuck W
Post by Chuck W »
Sveedy wrote: 23 Oct 2023, 13:49 ^ That is what I thought I was seeing. I'll measure both and go from there.
It's a pretty marked difference. The Turbo ones are like 43mm in diameter. The NA one is closer to 30mm.
Has thanked: 2200 times
Been thanked: 1852 times
Now is this just for 850's or all P80's? I remember years ago looking into axles as the Volvo part numbers seemed to change on a whim and then they seemed start rolling various part numbers into the same ones. It was frustrating to find what axle belonged to what model.
I'm happy to be corrected, but I would think that if a front wheel hub bearing fits all models, at least the outside splines should all be the same. Differences may be on the inner end if there is one. Some LH (shorter) axles have a metal balance weight, some have a big rubber donut on them, and some have nothing. The only thing is I seem to recall a long time ago finding there were different number of splines on some axles at the hub end. That may be wrongly remembered.
The main differences are on the AWD RH axle with the carrier bearing being different to to a FWD as it has a narrower shaft on the inner end to allow it to pass through the angle gear casing. Now I never did figure out if the AWD axle would fit a FWD car, but the reverse can't happen.
Then there are the final year 5 speed auto trans and finally the manual trans axles. Eek! :shock:
I do know the 5 speed auto axles for a 00 R are different to the 4 speed XC axles as I have both. The 5 speed auto axle is different as mentioned above. What I have not documented is if the FWD/AWD LH 5 speed auto axles are the same. I wrote some stuff on this thread:
viewtopic.php?p=628320&hilit=axles#p628320
Chuck W
Post by Chuck W »
*Shrug*
I dunno. All of my cars have been 850's.
The NA axle was from my '96 GLT manual.
