Hi,
Another electric conversion question here for my 1998 V70.
When I delete the internal combustion engine on my V70, I will also have no vacuum source to operate the brake booster.
So, I need to acquire a 12v vacuum pump, and maybe an accumulator tank. They are expensive! So I don't want to buy more pump than I need, but I certainly don't want less.
In order to size the pump, I need to know how much vacuum the brake booster in my car requires. Does anybody here know?
Thank you,
Thaddeus
What is the vacuum required (Hg) to operate the brake booster on these cars?
- ThaddeusTheBold
- Year and Model: 1999 S70 T5
- Been thanked: 10 times
- ThaddeusTheBold
Here is a vacuum pump for a 2006 Volvo S60 turbo. Do you folks think this would work?
https://www.rockauto.com/en/moreinfo.ph ... 5172&jsn=9
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Our P1 C30 uses a vacuum pump also. I think even our 03 S70 T6 has one. Go to any Volvo Parts Online and compare a heavier Volvo suv vs a car's vacuum pump. If they are the same part you should be fine.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
In keeping with the whole “Mathew” theme,
Check out Super Fast Matt on YouTube.
He’s converting an old Jag with Model 3 parts.
He has a couple of videos with conversion
info for power steering and power brakes
using Tesla parts.
And Bonus - Great Channel,
using Tesla parts.
- BEJinFbk
Ah! Here we go...
Be sure to watch all the way through to learn about
the less expensive Honda option. Forgot about that.
And while we're at it:
All Hail the Algorithm!
You get about 20 inches of vacuum at most on closed throttle overrun, so you don’t need more than that.
- ThaddeusTheBold
Thanks everyone!
- 912 Views
Last post by EstVolvo
- 12 Replies
- 3117 Views
Last post by Kulu
- 1922 Views
Last post by mrbrian200
- 396 Views
Last post by mmpeterson1850
- 2613 Views
Last post by DraftyBread
