95 850, no more door chime when key is in before starting car
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
The door chime is no longer ON when I inserted the key before starting the car, door was closed. It used to have chime for about 10 times and then stopped or chime would stop when I start the car. Now, no chime at all. When door is open, chime is working fine.
Any suggestion is appreciated.
Thanks.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Maybe you need to replace the chime. It's a little blue box that looks like a relay, and it's located next to the steering column under the dash.
I have a box of about half a dozen of these, because the very first modification I do when I bring another Volvo home is to yank these annoying suckers out :shock:
I travel to Boston frequently, if you want me to bring you one, let me know.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
lcc014
Post by lcc014 »
Thank you for the information about the chime. I will check it out first, thanks again :D
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Something that I'm happy to say UK cars never had
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
lcc014
Post by lcc014 »
P80GLT wrote: 26 Oct 2023, 10:44 Something that I'm happy to say UK cars never had
:D
lcc014
Post by lcc014 »
It turned out to be the micro switch inside the seat belt catch was broken. It is open all the times even after the seat belt is inserted. Chime relay is fine. The only way to fix this, I think, is to replace the seat belt catch.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
I dont even know how you found that. I would never have tgought to check that.
lcc014
Post by lcc014 »
ZionXIX wrote: 28 Oct 2023, 06:24 I dont even know how you found that. I would never have tgought to check that.
I found the wiring diagram of 855 wagon. The chime circuit has 2 branches, one for driver side door and the other went to a micro-switch inside the driver side seat belt catch and then to ground. This was for seat belt reminder purpose. Once seat belt is inserted into the catch, micro-switch will be in open state and stops the chime. Seat belt catch cannot be disassembled so need to get a new or used one.
Has thanked: 1610 times
Been thanked: 4065 times
You might be able to defeat it by removing the S terminal on the ignition switch electrical part, check the logic state of that to see if its NC or NO
lcc014
Post by lcc014 »
Will check that, thank you.
