CEM 11 PIN
- xiaofei204716
- Year and Model: XC90
- Been thanked: 2 times
What do you think can be used to parse the CEM 11PIN from the LOG of the VIDA configuration test? Currently, only low-level PINs can be parsed. I would like to use it to add keys through DSA.
ClarkLittel
- Year and Model: V40 2018
The CEM 11PIN is not easy to obtain, as it is stored in a secured memory of the CEM, and it is different for each. The VIDA configuration test can only read the low-level PINs, which are not enough to access the CEM settings. To parse the CEM 11PIN from the LOG of the VIDA configuration test, you need to use a special software or hardware that can crack the code by brute force or other methods.xiaofei204716 wrote: 26 Oct 2023, 07:01 What do you think can be used to parse the CEM 11PIN from the LOG of the VIDA configuration test? Currently, only low-level PINs can be parsed. I would like to use it to add keys through DSA.
- xiaofei204716
How do you do
Who can not connect the car only order configuration test software without installation, grab the PIN, please advise.
duzi
- Year and Model: S60
- Has thanked: 18 times
- Been thanked: 5 times
Is it possible to calculate the pin from the dump?ClarkLittel wrote: 04 Jan 2024, 02:10The CEM 11PIN is not easy to obtain, as it is stored in a secured memory of the CEM, and it is different for each. The VIDA configuration test can only read the low-level PINs, which are not enough to access the CEM settings. To parse the CEM 11PIN from the LOG of the VIDA configuration test, you need to use a special software or hardware that can crack the code by brute force or other methods.xiaofei204716 wrote: 26 Oct 2023, 07:01 What do you think can be used to parse the CEM 11PIN from the LOG of the VIDA configuration test? Currently, only low-level PINs can be parsed. I would like to use it to add keys through DSA.
- xiaofei204716
Now you just tell me the vin, and you can crack the pin. I have broken through this technology.
deltawing21
- Year and Model: s902019
it's very easy to do this if you have access to VIDA, decrypting the data. it was interesting to find out how we can read CEM memory using level 1 CEM pin, parsing the memory that contains seed, key or pin for level 11 (which are the addresses that contain this data, i really want to know)
- xiaofei204716
I don't know the calculation process, I don't know it, I only know that the analyzed result is correct and can be applied to orbit, p3tool, vdash, dsa, dha, smok, k518 and pd.
deltawing21 wrote: 26 Sep 2024, 15:40 it's very easy to do this if you have access to VIDA, decrypting the data. it was interesting to find out how we can read CEM memory using level 1 CEM pin, parsing the memory that contains seed, key or pin for level 11 (which are the addresses that contain this data, i really want to know)
Hello, I have access to VIDA, but I don't know how to get the CEM/INMO PIN. Can you help me? Thank you.
- 16 Replies
- 12342 Views
Last post by Rgierer
- 3475 Views
Last post by RickHaleParker
- 11 Replies
- 19404 Views
Last post by jarkmackson
- 1880 Views
- 750 Views
Last post by oscilloscope
