Battery Charging at 18 Volts
Alexjordan22
- Year and Model: 2005 XC90 2.5t
- Been thanked: 4 times
I noticed my battery was hot while running so I put my multimeter on it and sure enough it's showing 18+ Volts while running. Am I able to just replace the voltage regulator since I know the alternator is working? 1994 850 NA
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The regulators are replaceable. They're just kind of a bear to replace while the alternator is on the car.
Getting the radiator cooling fan assembly out of the way will give you more working room.
- Has thanked: 987 times
- Been thanked: 1075 times
Make the alternator repair soon, or the high voltage will ruin the battery and maybe other electrical devices including bulbs.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Double ditto; Robert replaced one on his ride not long ago without taking it off, but:
1) he is a Magician, and 2) he has pulled dozens from cars in salvage yards, and you know what they say about practice.
He is also big on doing the mod t hat puts the fan inside the shroud. Makes life a lot easier, even on the N/A cars.
- Chuck W
Yeah, I've tucked the fans on both of our cars. Makes a big difference in room on the front of the engine bay.foggydogg wrote: 30 Oct 2023, 20:39 Double ditto; Robert replaced one on his ride not long ago without taking it off, but:
Removing the fan shroud isn't all that much work, though.
- 2269 Views
- 550 Views
Last post by mar601
- 878 Views
Last post by Gobblin81
- 28 Replies
- 4139 Views
Last post by RickHaleParker
- 774 Views
Last post by RobsS40
