1992 Volvo 240
Bluesquaretatt2
Year and Model: 1993 Volvo 240
Post by Bluesquaretatt2 »
Hi, I own 3 Volvo 240 wagons , dark green 93, burgundy 92, silver 92
I kinda love Volvos
Anyways, none of them will pass smog. Here is the information I have on the burgundy 92 Volvo. I don’t understand. It runs so smooth. Like a champ! It failed twice! Would come one please tell me why? I hope it doesn’t need a new cat
Here is a photo of the test results
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 55 times
Been thanked: 28 times
Post by SOURDOUGHJIM »
Just doing a quick internet search, I came across this thread on high NO reading. Timing and EGR function are mentioned. https://community.cartalk.com/t/ca-emis ... d/32210/15
I live in rural flyover country so I don't have to deal with these issues.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
I am no expert, but it looks like the tester highlighted high HC and NO. I think this means Hydrocarbons and Nitrous Oxide. High hydrocarbons may indicate a rich fuel condition and high NO is often caused by high combustion temperatures.
Suggestions are check fuel pressure - low pressure may make poor spray pattern at the fuel injectors. Dirty and worn injectors can also cause rich mixture. IPD Volvo has injectors for $37. Also try Tectron fuel system cleaner.
Also clean and replace spark plugs for better combustion. I failed a Colorado emission test years ago and new plugs made it pass.
Volvolugnut
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
What I am about to suggest is naughty. I worked many years at a Buick dealership in Florida during the emissions testing phase. In the early days before dealers could buy their own emissions station. All used cars had to go through a state inspection station. Certain cars were known to fail so the mechanics would always disconnect the vacuum hose to brake booster to create a massive leak. This always worked for a sniffer test. If a car had failed previously which would require a load test on a dynamometer. Five gallons of 100% ethanol racing fuel would be added to the tank and the car would be driven hard to the inspection station. These days find a E85 station would likely replace the drum of ethanol racing fuel. This always worked for the load test. I left Buick in 1994 and the last year I was there we had a station. Henceforth all cars would be a new Buick actually taking the test even if the vin number was a Honda Prelude (the worst car to test) lol. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June, I guess the prosecution limits have expired. That is quite a story.
I always read when you make comments because they are so interesting.
Has thanked: 1610 times
Been thanked: 4069 times
volvolugnut wrote: 02 Nov 2023, 08:21 June, I guess the prosecution limits have expired. That is quite a story.
Also, there is no extradition treaty between AK and FL...
