Hello to All
Newbie here - Love the xc90 but found oil in the expansion tank. I thought it was the cooler changed it and then bypassed it because I have the same issue.
Oil continuously floats out of the tank so obviously a leak somewhere, since I have the cooler bypassed I suppose it must be the head gasket??? - Unless there is another area oil can leak into coolant. When I did change the cooler I found an amount of coolant in the sump.
Any advice appreciated.
https://1drv.ms/v/s!Al_IUBrJS97YhtNw3_I ... A?e=jeZn8J
Regards to all
Terry
Oil Ooze from coolant tank - Oil Cooler bypassed :-(
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Not quite so much oil but that was the first thing that came to mind
. How did you bypass the cooler? Did you check the dipstick to see if the oil is milky?
- 760 Views
- 2261 Views
Last post by fitz548
- 30 Replies
- 6119 Views
Last post by mhgreen
- 1645 Views
Last post by SuperHerman
- 1370 Views
Last post by jonesg
