High beams not working. Topic is solved
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Now with daylight savings, I am driving my 2002 v70xc in the dark more often. When I turn on the high beams, the indication light comes on, I hear a relay click, but the high beam lights do not come on. This has happened before, but intermittently. If I turned the high beams on and off a bunch of times, they would turn on properly. However, now they do not come on at all. What could be the problem? Is the relay bad?
2002 v70 X/C 288k miles
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Turn the headlamp switch on to the 12 o'Clock position
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
02V70
Post by 02V70 »
Tried it with that switch in every position. High beams wouldn’t even flash.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Check wiring and connectors to the high beam bulbs. Check with voltmeter to see that power is getting to the bulbs. Check resistance across bulb for burnout of bulbs.
Both bulbs may have failed or wiring problem.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
02V70 wrote: 10 Nov 2023, 22:35 Now with daylight savings, I am driving my 2002 v70xc in the dark more often. When I turn on the high beams, the indication light comes on, I hear a relay click, but the high beam lights do not come on. This has happened before, but intermittently. If I turned the high beams on and off a bunch of times, they would turn on properly. However, now they do not come on at all. What could be the problem? Is the relay bad?
Likely the high beam relay located on the CEM. You can swap it around with another relay to confirm. Since you can hear the relay click it's probably bad contacts within the relay.
Location of high beam relay (2/63).
HIgh beam relay CEM location.jpg (64.04 KiB) Viewed 556 times
02V70
Post by 02V70 »
The relay looked like this. I swapped it with the one for the fog lights, and now the high beams work!
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
02V70 wrote: 11 Nov 2023, 15:25 The relay looked like this. I swapped it with the one for the fog lights, and now the high beams work!
You may have company!
