98 S70 Radiator petcock
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
I know the radiator was replaced a long time ago. I'm having a real problem opening up the drain. It looks like plastic, like a wingnut so I'm using my hand and I'm afraid of breaking it as It's impossible to turn. (CCW right?). Anyway -- is there a trick to this?
I saw where the OEM radiator uses a 13mm socket but like I say this looks like the wing on a wingnut. -- thanks
Has thanked: 1613 times
Been thanked: 4078 times
The Nissens get s a quarter turn and then pulls down. If it doesn’t come, leave it and pop off the lower hose to drain
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
I'd suggest putting some silicone grease all over the threads and o-ring when/if you can get it out. Should make it easier to remove next time around.
2023 Lexus RZ450e -66k
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I never fool with it. Just loosen the lower hose and " control " the draining from there.
1999 V70 GLT
