This is a new one, maybe, for you folks. I have been chasing an intermittent failure to start. Replaced fuel relay, fuel pump, injector seals, ECT. Thought I had it fixed until tonight.
I had previously had ECT codes even after replacing the ECT. I finally cut the wires and respliced. Since then, I've had no other 123 codes on A2 or A6.
I plugged the wire into A2 tonight and the light illuminated without any button press. If I pressed the button, the light would get brighter, but didn't respond as usual. Couldn't read, couldn't clear. The other ports responded as normal.
I'm praying this is a clue to what is finally wrong with this thing.
93 850NA A2 OBD light on as soon as plugged in
- 4166 Views
Last post by erikv11
- 12 Replies
- 3467 Views
Last post by polskamafia mjl
- 23 Replies
- 4395 Views
Last post by bmdubya1198
- 1167 Views
Last post by SuperHerman
- 989 Views
Last post by RickHaleParker
