Volvo s70 2.5 t/belt wobble
Volvos7025
- Year and Model: 1997 Volvo s70
Hi I’m new to Volvo and iv just had my t/belt changed with genuine Volvo belt and idlers as well as new tensioner and aftermarket water pump from scandix Volvo and there is a slight wobble in the belt, just wondering if a bit of wobble is normal.and just wondering if it’s ok for it to be right on the edge
IMG_4031.MOV- (49.75 MiB) Downloaded 69 times
- Has thanked: 2199 times
- Been thanked: 1851 times
This seems to be becoming a regular issue. It does not tend to be down to one particular issue. The fact you used all original parts you would think that it should all be good, but not even OE parts are as good as they once were. I see you sued a Skandix supplied water pump. Do you know the brand? Again, I usually only recommend OE or OEM (Aisin) pumps due to other members saying they have had issues with other brands.
Having watched your video, it does not look excessive. Belts can take a bit to settle in. It also looks like you replaced the hydraulic tensioner. Was it OE?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Do this at your own discretion and potential peril!
Take a piece of chalk and slowly go near the moving belt till it makes contact with the wobble in question. If it only hits one spot on the belt then most likely the belt width is slightly off. If it's all over then it could be the belt and or other parts. The only way to find out in the second scenario is noise or side belt wear down the line.
Agree with Neil doesn't seem excessive so time will tell.
Volvos7025
Hi thanks dor the quick replies (Neil) it was a genuine tensioner aswell bet I’m not sure who the manufacturer of the water pump was but I will have a look and see if it was a ai sun or not.
Hi Movolvos thanks for your advice I will try try the chalk idea and see if it’s just on one bit although I did notice I could see a bit of brown string on the belt on a certain length of it so I don’t know if that’s just a manufacturing defect or if the belt is catching I’m unsure but I did about 300 miles after the video was taken so I will take the cover off again at the week end and see if there is any more signs .
Volvos7025
- MoVolvos
Let's hope it's just the belt and still within tolerance so you don't have to redo the work.Volvos7025 wrote: 13 Nov 2023, 12:42 Hi thanks dor the quick replies (Neil) it was a genuine tensioner aswell bet I’m not sure who the manufacturer of the water pump was but I will have a look and see if it was a ai sun or not.
Volvos7025
Hopefully i do t really mind the wobble on the gears I just don’t want it to start shredding and then snap or something like that 🫣
It is not possible to tell the brand of the water pump from the Skandix picture. In the picture it looks like it has a brand logo on it but as the 2 options they have look the same it may be a generic picture.
- MoVolvos
Age and heat is usually what causes a normal belt to snap. In your case there would need to be lots and lots of shredding but you would have caught it via noise or a visual inspection before it progressed anywhere near that condition.Volvos7025 wrote: 13 Nov 2023, 13:05 Hopefully i do t really mind the wobble on the gears I just don’t want it to start shredding and then snap or something like that 🫣
- 16 Replies
- 3731 Views
Last post by Clemens
- 1353 Views
Last post by vtl
- 15 Replies
- 2355 Views
Last post by xHeart
- 18 Replies
- 3858 Views
Last post by soulvoid1990
- 797 Views
Last post by iruleyounow
