P2 control arms - Meyle or Lemforder?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Need to replace control arms on the green XC70. Can anyone recommend one manufacturer over the other on this part, Meyle or Lemforder?
I’ve always used Lemforder (OE) but maybe there were some doubts on the forum recently about their quality/longevity?
The Meyles cost $50 more each arm, currently down to $35 more each due to sale at FCP. Maybe I’ll go with Meyle this time so I can compare them with the Lemforders I recently installed on the black XC70.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
They rip because the installer doesn't preload the arm to normal ride height before cinching down the bolts at the frame end.
I used a second jack and raised the knuckle to normal ride height, I had marked it before jacking the wheels off the ground.
Paid around $175, 5 years ago, don't know which mfger.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
erikv11 wrote: 16 Nov 2023, 08:56 Need to replace control arms on the green XC70. Can anyone recommend one manufacturer over the other on this part, Meyle or Lemforder?
Have you considered re-bushing the control arms? I purchased a set of front poly and the heavier duty Volvo XC90 back ones but never installed them on my 03 S80 T6. Perhaps they will go on my Project 07 S60 2.5T.
Front Poly
https://eeuroparts.com/product/professi ... 61435971PU
XC90
https://www.fcpeuro.com/products/volvo- ... 2w#fitment
XC90 Poly
https://www.fcpeuro.com/products/volvo- ... x-pff88600
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
I've used both brands. No issues.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
Post by erikv11 »
jonesg wrote: 16 Nov 2023, 14:16 They rip because the installer doesn't preload the arm to normal ride height before cinching down the bolts at the frame end.
FYI - preload is not an issue for control arms on P2 cars like it is on P80 cars. On a P2 the control arm bushings have a different design and can only mount at one fixed (and correct) angle. So no need to preload on a P2, jacking up the arm before tightening has zero effect here.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
erikv11 wrote: 17 Nov 2023, 00:19
If this is true, could I potentially replace the P2 control arm on a non-level surface where the weight of the car is not distributed evenly?
Post by erikv11 »
Sure, you could. Or jack up one side replace it, then drop the car back down and go do the other side. When you tighten the control arm to the subframe it is hanging free and has no weight on it at the spindle end.
But be careful/safe about raising up the car on a non level surface!
dikidera
Post by dikidera »
Oh yeah I definitely had it slide once and barely held it from falling, but in my defense I am not using the right jack. Luckily I had a lot of blocks of wood and the tyre underneath so damage would've been minimal.
