97 Volvo 850 Basic wagon PNP Switch
andrewjllrar
- Year and Model: 1997 850
- Been thanked: 2 times
- Has thanked: 311 times
- Been thanked: 817 times
It's been so long since I took one off ... I don't remember!
Curious to hear the resolution though.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Pry it off with a flat screwdriver but gently.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
andrewjllrar
Yeah, not budging… even with that.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Muck of Ages, spray with the magic fluid of your choice. Don't forget to block the wheels too, the car will try to roll once it's free.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I replaced mine earlier this year (in Jan 2023 on a '97 855) and the PNP switch just pulled up and off with a little lifting force. It looks like you've got all the nuts removed, so it should just pull up. If they will fit, you could try using two small nylon pry bars on each side and prying up. Good luck!
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I agree, it seems that you have all the appropriate bolts removed, it's now just a matter of freeing the PNP from the shaft. Liberal use of your favorite penetrating fluid, (I've had good results with PB Blaster,) let it sit for a while, and work it back and forth.
Good luck!
Roger
Good luck!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
andrewjllrar
Screwdriver didn’t work. Rivet removal tool did the trick.
- 11 Replies
- 11393 Views
- 16 Replies
- 1042 Views
- 1257 Views
Last post by volvolugnut
- 2051 Views
Last post by jimmy57
- 2467 Views
