I had a bugger of a time getting a replacement CV shaft into transmission a month or so ago. I tried transplanting the circlip from old shaft, etc, just wouldn't go in no matter what I did if the circlip was on it. Eventually I slipped some wheel bearing grease on and in the groove of where the circlip lives as well as over said circlip. This did the trick and it slid in like butter. Prior everything including a hammer on the end was tried - it would not budge.
So the next time you're fighting with it, give it a try. It doesn't take much...
CV Shaft replacement tip for circlip - shaft won't go in
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
- Been thanked: 4063 times
Yeah, the trick was the grease centered the slip ring and holds it while you insert. Once it drops, the ring hangs up on the edge.
- 1630 Views
Last post by rocketman4321
- 1425 Views
Last post by metalriff
- 2970 Views
Last post by JRev
- 11 Replies
- 8020 Views
Last post by xyourobob
- 758 Views
Last post by Jootteporin_kiina
