hey guys!
happy December
5x108 lug pattern
can I put 16 inch or even 17 inch tires/rims on my car?
I have 15 inch tires rims steelies on there now
thanks!
1998 v70....larger rims and tires
- Has thanked: 2199 times
- Been thanked: 1851 times
Yes you can. Make sure the center bore is the same. P80 and P2 wheels fit. If you want wider tires and rims be careful of rubbing on the inner fender at the front and rubbing on the parking brake cable at the rear. Offsets vary. Standard is around 43mm.
I should have added, center bore is 65.1mm for P80/P2. Careful on height of tire. At rear less of an issue, but at front the spring seat limits too much additional height in the tire.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
P2 cars usually have offset(ET) from 49-52 and rims are 7J(a bit wider).
Be carefull about ET because the tyre can rub on inside on a front struts.
On 850...limit for for ET number is 49 with 7J rims and 205/55/16 tyres.
215 and they rub on inside on front struts.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
I was pushing the size on my 98 V70 AWD. I had 225/40ZR18 tires on mine. I had slight rubbing at full lock on the front only. My rear suspension is different than fwd. My rear wheels camber in when the suspension compresses, if it didn't do that, I'm sure I would get rear fender rub as well.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
ok I got the exact tire size....
235/65/17
seem a little tall with that 65 in there!
235/65/17
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
A 65-series is gonna be very big for a 17" wheel.
I'm running 225/45s on the 17's I've run on our cars.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
I am not sure I understand the phrase "Be careful" in this context. That's because if you put the new, larger wheels on, they either hit or they don't hit, so how do you "be careful"?
I would think this is a go or no-go situation, but is there a way to modify something if they do hit?
surfbug1
ooops
225/55/r16
fat fingered it!
I have two on the front
they rub sometimes, but not while going straight lol
I have to replace the tires, rims are great!
205 215 225
or 45 50 55 60
what sizes are u guys running in 16 in tires
Al
225/55/r16
fat fingered it!
205 215 225
or 45 50 55 60
Al
Ping me!
Ping me!
- V50M66
- Has thanked: 26 times
- Been thanked: 94 times
205/55 is what you should be running on a 16" wheel for P80
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- 3129 Views
Last post by 93Regina
- 657 Views
Last post by tryingbe
- 3281 Views
Last post by Rattnalle
- 1975 Views
Last post by motormikeyman
- 482 Views
Last post by BlackBart
