Radio removal??2004 XC90 to install Parrot Blue tooth
merk850
Post by merk850 »
Hello,
I would to install the Parrot 3200 buletooth myself. I am told there is a wireharness made for my 04 xc90 that will make this as easy as pluggin in the harness to Parrot and radio?
Does anyone have specific directions on how to remove radio (non-premiun) I have a general idea of removing shifter trim and screws under climate control. However I read " Do not remove connectors before turning the ignition off"
WHen should I turn ignition on during this removal process and when should it be off? Is batttery always disconnected first. I am new at this but want to give it a good try.
ANy specific info would be greatly appreciated.
Links to a remaval page would be great. I have not come up with a detailed one yet.
Thanks,
Wayne
jlssecurity
Post by jlssecurity »
It seems a long time since this post. Hope you got sorted in the end?
Removal of the XC90 H/U is very straight forward.However the SOT integration harness also requires access to the amplifier under the drivers seat.
Remove the gear shift surround trim. Located at the bottom of the radio / heater panel there are 4 torx sxcrews. Remove the lower two. The complete panel will now remove outwards from the bottom. Allowing the top of the radio panel to drop from under the upper dash.
jlssecurity
