2003 s40 so sad
davidchecker
- Year and Model: 2003 S40
I was going to replace the fuel pressure regulator in order to get the startup to work smoothly without having to crank it two times. Then I noticed shavings, then I noticed they were rubber shavings from the serpentine belt, then I noticed all the oil everywhere on that side of the engine. The dipstick appears to be quite void of oil. I suspect something's blown, like a seal perhaps.? No oil dripping on the ground as if from the oil pan. The timing belt seems fine. just wondering what kind of pain I'm in for, depending on if I try to fix this myself or pay someone, though at this point I'm not sure what it is. Thoughts?
davidchecker
Seems like it might be the VVT gear seal. Will know more once I clean up the frkn mess.
- 17 Replies
- 5119 Views
Last post by matthew1
- 17 Replies
- 2966 Views
Last post by bmdubya1198
- 946 Views
- 1196 Views
Last post by alschnertz
- 712 Views
Last post by oragex
