Dylia 2000 S70 GLT 673289
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
Has thanked: 1610 times
Been thanked: 4065 times
Working up a refresh for a beautiful 421 green S70 in SOuthwest CT
Oil on right side of engine, probable cam seal leaks.
Using no oil between gas stops
Needs oil cap gasket
Needs battery
Cooling group refresh, has Volvo hoses, age?
Seal leakage probably needs timing belt rubber refresh
Strong smooth engine
Good tire wear, brake wear
Rear antenna needed
Driver window loose on track
No codes
PB shop in Kent or a Spinner trip
