I'm having a problem with my turn signal not turning off when it's supposed to. After making a turn, the signal will not click off when the steering wheel returns to centre. I suspect there is something broken off inside the steering column. Does anybody know what I should check or how I can fix this. It's getting annoying to have to manually shut it off each time.
Thanks for your help,
Nick
Turn Signal Won't Automatically Shut Off - '98 S70
CarVolvo
- Year and Model:
unlike some of the older cars.. there is nothing inside the unit you can really fix.. you have to remove the whole unit and replace it.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
JRL
- Year and Model: Several
- Been thanked: 16 times
Not exactly true.CarVolvo wrote:unlike some of the older cars.. there is nothing inside the unit you can really fix.. you have to remove the whole unit and replace it.
The clock springs can break and if you're resourseful sometimes it can be fixed.
If you DO need a turn signal unit, (complete), I happen to have one you can buy from me. ($50.00)
Thanks for the info JRL. Do you have any more information exactly how to fix the springs or know where I could find it. I would like to know what I'm doing before taking it apart. If worse comes to worse I'll try to figure it out.
- 2182 Views
Last post by BEJinFbk
- 4661 Views
Last post by June
- 422 Views
Last post by P80GLT
- 1897 Views
Last post by s80volvo2004
- 1540 Views
Last post by Oka
