Do the P80 2000 S70 and P2 2009 S60 2.5T AWD share the same strut mount and strut bearings? I sorta remember reading some where that it's interchangeable with the XC90 and being stronger?
P80 & P2 Strut Mount, Bearing & Upgrade Options 30683637 30647763 8646713
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- Has thanked: 2199 times
- Been thanked: 1851 times
XC90 is now the standard one from Volvo. They all (P80/P2/XC90/S80) all use the same one.
https://www.volvocarstorontoparts.ca/p/ ... 83637.html
- MoVolvos
Thanks Neil. Makes it easy for the fleet!scot850 wrote: 25 Dec 2023, 23:12 XC90 is now the standard one from Volvo. They all (P80/P2/XC90/S80) all use the same one.
Added part numbers to title for search
30683637
Supersession : 30647763; 8646713
30683637
- MoVolvos
.abscate wrote: 26 Dec 2023, 04:26 Added part numbers to title for search
30683637
Just thought of something else. Not sure if anyone has looked into this but if the strut mounts are the same I'm wondering if a Complete / Easy Struts would be interchangeable also?
Example would be 03 S80 T6 - 00 S70 SE Base - 09 S60 2.5T AWD - 07 S60 2.5T. Perhaps the strut valving and spring rate are different but is the assembly in terms of size and shape are the same.
Have a set of fairly newish Complete / Easy Strut that I would like to remove from the 03 S80 T6 to swap with other cars for testing. The struts in the other cars are not leaking but may be worn.
- 16 Replies
- 4314 Views
Last post by JRev
- 1102 Views
Last post by oragex
- 148 Views
Last post by cn90
- 11 Replies
- 580 Views
- 889 Views
Last post by GreenMagicMan
