Manual flywheel bolts?
oldschoolvolvo
Year and Model: 1979 242DL
Has thanked: 1 time
Post by oldschoolvolvo »
I need a sanity check...I bought OE flywheel bolts (9454743) and a 12mm XZN bit, but the bit clearly doesn't fit the bolt (too big). I'm wondering if the 12mm bit I bought is oversize. What gives? Appreciate any feedback.
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 55 times
Been thanked: 28 times
Post by SOURDOUGHJIM »
There's a socket set available on Amazon for $19. See this thread....
https://www.swedespeed.com/threads/inst ... ed.197270/
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
If you bought both from FCP a phonecall might clear things up. Is this what you have ?
https://www.fcpeuro.com/products/12mm-t ... t-cta-8514
oldschoolvolvo
Has thanked: 1 time
Lesson learned, don't assume the tool is correct.
@foggydogg Thanks for the link. I didn't realize FCP sold individual bits or I would have purchased both together and avoided this confusion. :oops:
Turns out the 12mm XZN bit I got on Amazon is oversized and was causing my confusion.
I got a different bit at Advance Auto and it fits just fine. Problem solved.
Fair warning, this bit may or may not work:
https://www.amazon.com/gp/product/B00ES ... =UTF8&th=1
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
