There is a faint metallic noise coming from under the car when driven. It's like a ball bearing sitting on a glass plate being rolled around sitting on something that would fast vibrate the plate. Another description would be like that of a small piece of metal bring dragged by the car but the sound is at a very high rate of frequency and very very faint.
09 S60 2.5T AWD Faint Metallic Noise
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
if the sound is central , look at the heat shield above the prop shaft ,
if located at a wheel it could be the dust shield that backs up the brake disk.
Both are flimsy , easily bent and cause noise.
- MoVolvos
.jonesg wrote: 31 Dec 2023, 03:33 if the sound is central , look at the heat shield above the prop shaft ,
Thanks, I give those areas a look.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
My girlfriends car had some debris on the rotor. We cleared it up with a brake clean bath while spinning the rotors. I had my rear rotors chirp like a bird when i got some rust proofing spray on them. Same method to clean them up.
2008 S60 2.5T Auto (Sold)
- jonesg
thank you for being a bot.ellylittle wrote: 14 Jan 2024, 20:58 I think this post is very helpful and full of useful information. So, I'd like to thank you for all the hard work you put into writing this article.
- 1829 Views
Last post by xHeart
- 19 Replies
- 1684 Views
Last post by hu5ker555
- 757 Views
Last post by Randall0208
- 2120 Views
Last post by CoupeC70
- 912 Views
