Using Vida On Virtual Machine - Any Disadvantage?
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Connecting Volvo to Vida, through a virtual machine, what would be the disadvantage?
Cheeers
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Cumbersome. A VM is a resource hog. Works perfectly fine directly on actual hardware even Windows 11.
It's just a roundabout way to run VIDA. Like writing a GUI in visual basic to track the killer's IP.
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
I run it in a VM on a Linux laptop no problem. Performance doesn't seem to be an issue. Previously, it was in a VM on a Mac, again no problems.
dikidera
Post by dikidera »
If your primary OS is not Windows then sure. But if it is, I see no reason to.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
dikidera wrote: 09 Jan 2024, 05:13 If your primary OS is not Windows then sure. But if it is, I see no reason to.
Who in 2024 has Windows as a primary OS? Why? What for?
In 2024 even nested virtualization (virtual machine in virtual machine on hypervisor) is not bad at all.
dikidera
Post by dikidera »
It's been my primary OS since the early 2000s. I do occasionally use Linux and I am not a stranger to compiling kernels, I've done that quite a lot. But still Windows is my primary OS.
Oka
Post by Oka »
Thanks every one for your replies and info, I really appreciate it all !
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
I had Vida on a VM (Mac, Intel) and Windows XP (yes this was over a decade ago) caught a virus. It was not salvageable via any reasonable amount of effort, so I nuked the whole thing with one button click. Poof. Problem solved. :lol:
I think then I cloned a sibling VM with a bare Windows install on it, installed Vida, and was back in business in just minutes of actual human time/effort.
If you think of VMs as disposable, this strategy can save time and headaches. But keep it just to Windows/Vida to make it easy to play to the strengths of this strategy. If you put lots of work/documents on the VM, and don't back it up, all the elegance and simplicity is absent, and you have all the traditional drawbacks of a physical PC you depend on.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
But to answer your question directly -- no drawbacks, all the physical ports are "there", and have been since the 2000s. A VM with Windows will "see" peripherals just fine. That problem was solved long ago.
Also -> Amazon link
Oka
Post by Oka »
The laptop I am going to use will only be for VIDA (VirtualBox) and a car scanning software on host (Windows 10). Just those two only, nothing else.
Would anyone have a VIDA in a Windows 7 OVA or VDI file I can use?
Or, is there where I can download one?
Though the VirtualBox installed will be on Windows 10 Pro x64.
Cheers
